D17 tractor
John Byrd
05-07-1999 14:02:06
I can't find a starter for my D17 diesel in the central Arkansas area. Starter # 1113082 Delco. Tractor serial #: D1722045D. Can anyone help? Is there a salvage dealer that I can contact? Thanks.
R Naak
02-25-2000 19:01:40
 Re: D17 tractor in reply to John Byrd, 05-07-1999 14:02:06
looking for original implements for a 1964 D-17 series IV Allis Chalmers - plow - pull behind mower - disc
Chad Wink
05-07-1999 19:17:33
They have to be out there, its not like its a rare tractor.
What's wrong with the one you have? I assume you do have one. I have had much better luck rebuilding my existing starters, generators, etc. I feel that the rebuilders only replace the parts they absolutly must to get it working again. Then they reuse parts that are 75% worn out, then in no time you need another one. If I rebuild it, I replace all of the parts that are worn or bad, and it lasts alot longer.
Wayne
05-08-1999 04:41:27
 Re: Re: D17 tractor in reply to Chad Wink, 05-07-1999 19:17:33
I agree with you. The starter on my Gleaner was kaput and we replaced everything inside the housing instead of just the bad parts like a rebuilder would do.
