12 volt wiring
Don
04-12-2004 05:22:59
Can anyone email or fax me a wiring diagram for a 12 volt generator and volatge regulator. I am assuming that as long as it is negative ground, hook up should be the same no matter the tractor. I would like a universal diagram for diagnostic purposes. thanks, Don
Tyler Herring
04-18-2004 20:29:30
 Re: 12 volt wiring in reply to Don, 04-12-2004 05:22:59
Hey, can I get that 12 volt wiring diagram too?
Don Dittmar
04-19-2004 04:51:05
 Re: Re: 12 volt wiring in reply to Tyler Herring, 04-18-2004 20:29:30
Tyler,
Steve sent me a real nice wiring diagram. Just email him and tell him what you are looking for and he will email one to you
Don Dittmar
04-13-2004 04:59:25
Thanks guys,
this helps out alot. Not having any trouble, just restoring a d14 that I want to switch to 12v neg ground. these diagrams should help after i change all my lights and add a resistor. thanks again,
Don
Duey (IA)
04-12-2004 19:49:41
I have a kind of generic diagram for a generator with a regulator on my website.
steve
04-12-2004 15:58:33
send me your e-mail address to [email protected] basically the generator has two contacts "A" and "F" or armature and ground. The voltage regulator has 3 terminals, "B", "G", and "F". the B is battery power from the amp meter, the G is generaotr or "A" on the generator and F is field, same as the generator F. The B power to regulator should be turned off with the key when not in use.--- to test a generator, ground the "F" to the case, start the tractor (or spin generator 1500 RPM with a motor) and read the voltage across the G and F termnals. should get about double what the normal battery voltage is. once the regulator is in the circuit you get 7 volts or 13.8 depending on 6 or 12 v system.
