Allis Chalmers
John
04-12-2004 03:43:41
Can Some body help me with som info about my tractor Model is a D-272 4 cylinder Petrol
I Need to now what year it is as i,v been looking on the net but not having any luck
steve
04-12-2004 16:11:34
 Re: Allis Chalmers in reply to John , 04-12-2004 03:43:41
john, i may be way off base, but i thought there was a D 272 model made in England during the 1960-70 era??? Maybe a british version of the D 14 or 15??? Some were probably sold in Canada. Who made the engine? does it have a plate? See if the tractor looks same age as an American D series in sheetmetal design. You can also post on Unoffical Allis home page and get more data from the guys. i might help if you send a photo [email protected]
Dick2
04-12-2004 04:25:38
You will need to find and post the serial number so we can determine what model you have. The serial number should be 4 to 6 numbers for most tractors, although some older tractors had 1 to 3 numbers.
John
04-12-2004 04:45:46
 Re: Re: Allis Chalmers in reply to Dick2, 04-12-2004 04:25:38
Thanks Dick2 ok the serial is located on the rear of motor from what i can see its { ECR17241 }
Nobody seems to now much about this tractor for some reason PS: ALso Dick i Have Some Pictures
If that can help
Thank you John
m.forest
04-12-2004 19:10:39
 Re: Re: Re: Allis Chalmers in reply to John, 04-12-2004 04:45:46
d-272 is an english model made from 1957 at Essendine,Lincolnshire, England. It succeeds the d-270 which was base on a B. 3 types of engine,Allis gaz, kerosene or perkins diesel.of 31 hp at 1900 rpm. 3.5 x 5 for 144 cu inc. or 126 cu inc for gaz. 4 speeds transmission and one reverse (like the CA) with hand clutch. wheelbase is 75 inc. Weight for gaz is 3200 and diesel is 3500. Import for sale in eastern Canada. No parts book or part available.Is it for sale?
m.forest
04-12-2004 19:16:49
 Re: Re: Re: Re: Allis Chalmers in reply to m.forest, 04-12-2004 19:10:39
my e-mail is [email protected]
Dick2
04-12-2004 07:53:38
Look on the transmission case ahead of the gear shifter quadrant and also on the differential housing for a serial number. The number on the engine may (0r may not) be an engine serial number only. Does this look like a 1920's - 1930's tractor - or newer?
