Getting down to the finer points on WD45
Vic Lovejoy
04-08-2004 10:50:13
I've gotten the WD45 running with the choke in. I got a blade-type feeler gauge and checked the point gap. It was way off, like .035. I adjusted it to .020. Checked the spark plugs which were replaced a couple of weeks ago, actually about 2 hours running time altogether. They had a black crust on them and the #3 was wet with oil. I cleaned them up and checked the gaps so now they are OK.
The engine is idling rather fast but the surge goes away at a certain rpm so it's not surging.
Now I'm going to try using it for some things, moving a hay bale, running the bush hog around the pasture, etc., to see how it's going to do.
I noticed that the bale spear on the 3-point hitch only moves about 7 inches when I move the lever all the way up - is there any way to set the hydraulic pump to get more of a throw on the bale spear? Just curious.
I'll let you all know how the running tests go.
vic
John (C-IL)
04-08-2004 18:30:32
 Re: Getting down to the finer points on WD45 in reply to Vic Lovejoy, 04-08-2004 10:50:13
vic, the total vertical travel tof the lift arms is around 15-18 inches, so the lift of your bale spear is probably more dependant on the linkage geometry of your attachment than the amount of lift. Watch the cylinders to see if they are extending all of the way, if they aren't, check your hydraulic oil level.
