Model B PTO gasket
CH
04-07-2004 12:51:50
If one of you folks has access to a PTO "with hydraulics" gasket, could you measure from the botton outside edge of the gasket to the top of the solid bottom half. I've got my old non-hydraulic gasket and want to cut a with hydraulic gasket. Thanks
steve
04-07-2004 15:14:53
 Re: Model B PTO gasket in reply to CH, 04-07-2004 12:51:50
i dont know what the height of the gasket is, but if you look at the "FILL" plug ont he side of the transmission, your gasket should be about 1 inch below this. that way you can fill the back end when the transmission plug is used, and if the tractor works nose down, you will retain extra oil in the back end available to the hydraulic pump without letting it fall forward to the front end.
CH
04-07-2004 15:49:32
 Re: Re: Model B PTO gasket in reply to steve, 04-07-2004 15:14:53
Makes sense to me, thanks Steve.
