Model B /runs perfect ,then all the sudden,,spit-s
Ryan L.
04-07-2004 06:50:14
I have a model B with woods belly mower. I have used this tractor for many years, two years ago i started having problems. The tractor runs great at all times, but then all the sudden while mowing it will start to spit sputter and damnere die, and then, like nothing was wrong it will take of and run perfect??? this will happen at any given time, just out of the blue. I'm a mechanic by trade and am still stumped. Last year I rebuilt the carb and know its working o.k., I had the head redone and checked, it's o.k., send the mag. off and had it rebuilt. one thing i don't know about is the mag. Could I be having mag problems or what, my expereince tells me i am losing ignition when this problem occurs. Is this an internal mag problem or whats happening??? Help. Thanks for info
Gene Cockrell
04-11-2004 23:43:25
 Re: Model B /runs perfect ,then all the sudden,,sp in reply to Ryan L., 04-07-2004 06:50:14
I had the EXACT thing happen to my 1940 B albeit with a 5X5 FMC pull mower. Turned out to be the oil seal in the back of the F-M mag. This was defective and would let a little hot oil through, just enough to gum up the points. I ended up having the mag case machined for a modern-type oil seal. Works perfect now...
Steve in N.J.
04-07-2004 19:23:44
Ryan,
You could be on the right track with your mag theory. If it's a "J" series Fairbanks mag, (two piece lower cover & cap) one of the quirks that Fairbanks had with the early "J" series was the tar taped coil they came with. After a while, these would start to "leak" and intermittantly ground themselves out to the mag housing or drive bearing. Fairbanks corrected this problem later on by replacing the old tar taped coil with an Epoxy type coated coil. We service and rebuild the F/M mags, if you would like to send it out to us for testing. Drop us a line if interested... Be glad to help you out!BTW- Thank You Rod for the referral!
Steve/B&B Custom Circuits
Ryan L
04-08-2004 05:25:52
 Re: Re: Model B /runs perfect ,then all the sudden in reply to Steve in N.J., 04-07-2004 19:23:44
Steve, I'm not sure what type of fairbanks mag I got, but I do need to have it checked. If that is possible? Like I said, it will run fine for awhile and then act up, so I don't know if its something you would be able to tell right off the bat?? Anyway, I would like to get your phone#, if possible. I do not own a personal computer, I use work computers, so if you would e-mail youre # to [email protected] and I will give you a ring. Need to get this taken care of before grass gets to long! Thanks, and I look forward to speaking to you. Ryan
Dick L
04-07-2004 17:55:57
Had that same thing happen with an Oliver 66 when I was mowing hay. Drove me up a wall. I was sure it was a fuel plug somewhere. I would take the sediment bowl off out in the field and gas would run out full stream. Took it off the last time and noticed that the fuel was running out quite well but seemed to not run straight down, kinda wanted to go sidways a little. Took the tank off when I had time and found a coin in the tank.
Tom Davison (PA)
04-07-2004 09:14:46
I have a 53 B that had similar problems. It was the mag. It would run good until it got warm, and then it would skip and act like it was not getting fuel. Had mag reworked and it now runs perfectly.
I have a 39 B that also had similar problem. This problem was with the carb. It was a new carb. The problem was the float valve. The new ones are rubber tipped, and they tend to stick. They will stick both open & closed. It would run until it ran the fuel out of the bowl and then die. After waiting a few minutes, and a few raps on the carb with a metal object, it would start and run for a while and then stop. I finally quit turning off the fuel when it was not running, and it now runs perfectly. It must be the float valve was drying out and this caused it to stick closed. Hope this helps. It also helps to have the floate set at the correct level. Tom Davison
Ryan L
04-07-2004 11:04:42
 Re: Re: Model B /runs perfect ,then all the sudden in reply to Tom Davison (PA), 04-07-2004 09:14:46
Thanks for the responce Tom. I'm an east central indiana native, is there anyone you would recommend I send the mag to? It is a 1938 B, and I'm almost sure it is an ignition problem by the way it runs perfect and then drops dead at the snap of a finger(like a light switch to the mag). As quick as it snaps off it snaps right back on,but never does fully die, and runs perfect.?
Tom Davison
04-08-2004 09:20:58
 Re: Re: Re: Model B /runs perfect ,then all the su in reply to Ryan L, 04-07-2004 11:04:42
I have never used him, but from all of the posts, I agree with the other gentlemen that Steve in NJ would be you best bet. Hope it helps. Tom Davison
Rod (NH)
04-07-2004 11:42:43
Hi Ryan,
Steve in NJ does a lot of B mag work. He will probably be by and respond to your post. He also has posted below so you may want to get in touch with him.
third party image Rod
Bushmaster
04-07-2004 19:11:35
 Re: Re: Re: Re: Model B /runs perfect ,then all th in reply to Rod (NH), 04-07-2004 11:42:43
Link
type in 2 words: miserable failure
