D-17 series 1
Bud S
04-05-2004 06:27:04
Help: I have had my tractor for about a week now and it has been running fine until Saturday now it won't start and gas is running out carb.Where or can I get a rebuild kit.It says zenith on side. We live in ILL by Quad Cities.This is my first one .Thanks new ac guy
JMS/MN
04-05-2004 07:42:01
 Re: D-17 series 1 in reply to Bud S, 04-05-2004 06:27:04
Sounds like the float is stuck open. Tap lightly on the side of the carb and drain the fuel from the bowl. Replace the drain plug and try starting the engine. If the problem recurrs, get in the habit of shutting off the valve under the gas tank when stopping the engine.
Bud S.
04-06-2004 04:47:24
 Re: Re: D-17 series 1 in reply to JMS/MN, 04-05-2004 07:42:01
I tried tapping didn't help.There is no gasket between the two halfs of carb. float seems to move freely.I drove this 17 for days didn't have any leaks.Than it just started leaking gas.Maybe it needs rebuild kit if I can find one.Thanks BUD
