Help with Identification
Mike in NC
04-03-2004 10:59:10
I just bought a nice little AC, but I don't have a clue what model it is. It is either a B, C or CA. It has a straight adjustable front axle. Are there any easy ways to tell which it is? Thanks in advance!
Kip [UT]
04-03-2004 16:12:31
 Re: Help with Identification in reply to Mike in NC, 04-03-2004 10:59:10
Serial # is located right next to shifter on all three models & will begin B,C,or CA. B only has steering drag link running level along bottom of the engine. C or CA runs at about a 45 degree angle across the engine to a secondary steering box instead of going directly to the spindle. Only CA has power adjust wheels,operators platform, & 4-speed. Beware as there are many mix & match B,C,CAs as most parts freely interchange between these models. Witch ever one you have, you've got a neat little tractor. I have all three models.
JMS/MN
04-03-2004 11:40:32
Only one with Power Shift rear wheels was the CA. Wheels had four rails that you could slide them in or out on, without unbolting wheels.
JMS/MN
04-03-2004 11:38:18
CA was a four speed, various fronts, B had 3 spds, arched wide front, C had 3 spds, various front styles, most common was tricycle, but wide was square tube.
