Allis-Chalmers CA, make a good puller?
earlschieb
04-02-2004 19:40:53
I just bought a 1951 Allis-Chalmers CA, anyone on here try pulling one? What weight class, and what all was needed to make it a decent puller? Thanks!
KIp[UT]
04-03-2004 16:36:08
 Re: Allis-Chalmers CA, make a good puller? in reply to earlschieb, 04-02-2004 19:40:53
I pull a stock wide-front 1950 "C". This tractor was very competitive @2500 lbs. It now has ballasted 11.4x24 rear tires & front engine weights & dominates the 3000 lb. class. Just get your CA running well & you can be competitive in classes between 2500 & 3250. I'm in way over my head @ 3500. Do it & have fun!
dave
04-04-2004 17:24:27
 Re: Re: Allis-Chalmers CA, make a good puller? in reply to KIp[UT], 04-03-2004 16:36:08
I pull a 41 C. I have won the 3500 against some wc's in the 275ci range. Rebuild the motor and head take about .040 taken off of the head, brought the motor really alive.
greg
04-07-2004 19:59:29
 Re: Re: Re: Allis-Chalmers CA, make a good puller? in reply to dave, 04-04-2004 17:24:27
I have a c-a that I've pulled some-what. I took 28" wheels from an old W-C, made an adaptor plate and put 14.9x28" tires on it Pulled in 3000&3500 pound class and was always in the top 3 out of about ten or more tractors. It is a lot of fun and is easy to transport up and down the road. Be sure to put wheelie bars on because they will not give out of power in 3&3500 class. Check the rules in your class as to what you can do with tire size, etc. Also check the rules on the draw bar location . Around 21" from the ground works good if they will allow it and the closer to the rear axle the better,[most tracks have a minimum lenth distance].I made a weight bracket for the front and rear and usually ran about 75 to 100 lbs on the front and the rest on the rear to make up the weight class. Good luck and have fun but be careful
Clarence
04-07-2004 16:40:12
I had a CA and it would not pull at all--the hand clutch slips. This is a very-very difficult problem to correct and the best way is to take the hand clutch out completely and put in a straight shaft---it will pull then. Probably in the 3,000 pound class. The other guys who responded to your question had "C" Allis, a cpompletely different animal from a CA.
