Rear tires on D14
LD from VT
04-01-2004 16:57:49
My rear tires are very cracked and appear to have a slow leak. Given their condition I checked with a couple of local dealers on replacing the tires but learned the size, 13.6X26, is an odd size and they cost about $380 each! If I could change the wheels and power adjust rims to 28" the new tires would be less than $200. Then again, buying the wheels, rims and tires will probably run more than the $380. Can I install 28" power adjust rims on the existing wheels? I may decide to live with the cracked tires and just have new tubes installed. Any other suggestions out there? Anyone have a set of decent used tires?
Thanks for any help.
JMS/MN
04-01-2004 17:53:48
 Re: Rear tires on D14 in reply to LD from VT, 04-01-2004 16:57:49
The wheel dish for a 26 inch is not the same as a 28 inch, so you cannot switch rims without the dish. As long as your existing tires have decent tread left, I would just put in new tubes, and leave the tires. It is possible that all you need are new stems in the tubes. If you go to 28 inch wheels, the ground speeds will be faster. Also check if you can go to a 14.9-26 tire with your existing rims. I think that was the oversize option when the D14 was built. If you check combine salvage yards you are likely to find either size 26 inch tires. I put front duals on my JD4450 two years ago and found 14.9-26 from a Case combine from the 70s.
ron
04-05-2004 18:09:38
 Re: Re: Rear tires on D14 in reply to JMS/MN, 04-01-2004 17:53:48
i just parted out a 600 case combine that has a set of 14.9-26 on it. the tread is deep and dont look wore, if any from new but i dont know how old the tires are. the side walls have small age cracks but nothing major. im located in kentucky and that will probably be too far for you. im asking 200.00 for the set and that includes the wheels.
mowr
09-15-2004 18:06:56
 Re: Re: Re: Rear tires on D14 in reply to ron, 04-05-2004 18:09:38
Do you still have your 14.9-26 Case combine tires and wheels? What part of Kentucky are you in? If we're close enough, I'd like to check them out. You can email me or call me at 513-479-6487.
mowr
09-15-2004 18:01:19
Do you still have your 14.9-26 Case combine tires and wheels? What part of Kentucky are you in? If we"re close enough, I"d like to check them out.
LD from VT
04-07-2004 17:57:19
Thanks for the note Ron. If I was a little closer I'd buy them, but Kentucky is probably too far. The shipping would cost more than the tires and wheels.
I've located a pair of 28" wheels/rims/tires off of a D15. Does anyone know if the D15 wheels will fit the hub and bolt pattern of a D14 (6" center hub and 8" between center bolts of an 8 bolt pattern)?
