Hey folks, I had a breakthrough in stud removal this afternoon. I was out dorking around the tractor while the horses ate, and went into the workshop to get the PB blaster. There, hanging on the wall, was a pipe wrench. Hmmm. I took it out and put it on one of the manifold studs that has the threads stripped of the end. It gripped the stud with the large teeth on the wrench. I put it about an inch away from the block (an inch up the stud) and started tapping the handle of the wrench with a hammer, about 4 inches up from the stud, very lightly. After a few taps the stud started to turn, and I just kept tapping, and turned it out as pretty as you please. I removed all the studs with the stripped ends like that and the 'new' studs screwed right in. I'll have to soak the new ones in WD40 since they're rusty, but they fit just fine. Now I have to worry about the stud that was broken off flush with the block, that I have been drilling with progressively larger bits. Hopefully I can find one more bit that will take the thing almost to the threads in the block, and get myself a tap thing like you guys have recommended. A question about the tap - do they come in a kit, like there will be a bunch of them? Should I take one of the studs to the store with me (like a Wal-Mart? or an Auto-Zone?) and just get one tap thing, since I only need one? I'm very excited about having figured out the whole stud removal thing. Anyone who has a stud broken off in a block or head, if there's enough of the stud sticking out to get a pipe wrench on it, that really worked slick. I'll keep you all posted as I get the last hole tapped and get the tractor back together. If this thing starts and runs you'll probably hear me hollering no matter where you live. Thanks for the advice! vic
