WC Manifold
TonyM
03-28-2004 20:19:17
A friend has an early styled WC with the side outlet exhaust (does not go through the hood). Brass, JB Weld, chewing gum, etc can't patch all the cracks and holes. Does anyone make a reproduction? If not, might someone have a good used manifold they would part with reasonable. Thanks in advance.
Vance
03-29-2004 14:59:18
 Re: WC Manifold in reply to TonyM, 03-28-2004 20:19:17
I have a Manifold like the one you are looking for. It had a small crack about half an inch on one end of the part that has vacume on it for the carb. I put jb weld on it last year and it works fine. I am putting a larger carb on mine and that manifold will no longer work for me as the new carb hits on the side of the block.It's on a 1950 wd all fuel.Make me a offer.
UUsee
03-29-2004 04:33:45
Valu bilt has one but you would have to change it to a thru hood exit.Then you can run a muffler.Did it to my 39 WC.
Karen
03-29-2004 03:16:02
I know someone that maybe able to help you. Email me
Kip [UT]
03-29-2004 21:25:43
 Re: Re: WC Manifold in reply to Karen, 03-29-2004 03:16:02
Have a good 45 degree manifold off a '39 WC also two uncut styled hoods from two different '39s. Manifold has good elbow, will sell for $90 plus freight.[435]691-3905.
