wd45 belt pulley
john
03-27-2004 22:59:47
hi all my friend got a wd-45 he was wondering how to turn the belt pulley on he said he turned pto on but the belt pulley didnt work what lever makes it come on
JMS/MN
03-28-2004 20:52:37
 Re: wd45 belt pulley in reply to john, 03-27-2004 22:59:47
Two posters mentions arrows. The arrow should have been stamped by the factory or dealer, indicating which hole in the pulley sleeve sets the proper backlash between the gears. The sleeve has a multiple of holes, but they are different distances from the end gear- the sleeve is rotated until proper backlash is obtained when the setscrew is tightened.
Dave K
03-28-2004 13:29:37
Above the pulley, on the frame or block is a big hex head screw with a lock nut on it. Back this off, push the pulley inward, being sure the arrows line up, move pulley shaft in and out a little as you screw the lock bolt back in until it seats in the slot on the pully shaft. Tighten down the bolt and lock nut. Do all this with engine off! The pully motion is controlled by the foot clutch. It should turn any time the foot clutch is engaged, even with tranny in neutral.
Dave
Joe M
03-28-2004 05:59:36
Send me your e-mail and I'll be glad to send you a scan of the belt drive page out of my manual
Roger
03-28-2004 03:01:19
on the frame beside the pulley is a tee handle or maybe just a bolt. loosen it and slide the beltpulley in until the gears mesh. There should be an arrow on the frame and pulley to show proper adjustment alignment. This must be done with the engine off. An operators manual will give complete instructions. Roger
