CA rear main seal
Greg
03-25-2004 21:22:21
Is there only one seal on the rear of the motor? I pulled my ca down to fix rear main leak. The only seal there is what was left of a felt seal. Is there another seal under the rear main cap.
Dick L
03-26-2004 04:08:18
 Re: CA rear main seal in reply to Greg, 03-25-2004 21:22:21
No Sir, there is not.
RSW
04-02-2004 14:29:11
 Re: Re: CA rear main seal in reply to Dick L, 03-26-2004 04:08:18
There is a wick in the crankshaft that allows oil from the engine to weep onto the clutch pilot bearing for lubrication. You may want to check the condition of this wick while you are in there, also make sure the drain holes are open in the flywheel.
