H3 Steering clutch adjustment
Jonny (GA)
03-21-2004 11:49:45
Can anyone tell me how to adjust the steering clutches on an H-3 crawler? I found the brake band adjustments but could not find the clutches. Thanks to anyone who can tell me anything.
hyperpack
03-23-2004 18:24:50
 Re: H3 Steering clutch adjustment in reply to Jonny (GA), 03-21-2004 11:49:45
The adjustment bolt for the steering clutch is on the outside of the final drive housing it is about a 1" diameter bolt with a hole crossdrilled through the end for turning it. The bolt is just inside the track sprocket on the final drive housing,look between the sprocket teeth just below the track chain.
Turn the bolt in to set less freeplay in the clutch lever.
Hyperpack
jonny
03-24-2004 19:10:04
 Re: Re: H3 Steering clutch adjustment in reply to hyperpack, 03-23-2004 18:24:50
Thanks for the info. Someone on the AC website already helped me but thanks anyway. All help is good. I looked past it several times but could not see it for the track and sprocket. Had to bend down and look up too see it. I need to turn them in but I can not turn the lock nut. May have to replace. Heated the nut after I took the whole thing out and still cant move it. Thanks again.
