Clutch adjustment
john
03-15-2004 15:17:52
Can anyone tell me how to adjust the clutch on a C allis. When the tractor is started it is hard to get the tractor in to gear. The clutch disc looks good. How do you adjust the pressure plate to make it go into gear easer. The tractor seems to pull good. Just hard to get into gear. Thanks for any help. John.
steve
03-15-2004 18:44:20
 Re: Clutch adjustment in reply to john , 03-15-2004 15:17:52
if you are inside looking at the pressure plate, the three fingers should be adjusted with the three little screws so they all have the same lift. if the tractor is assembled and you are on the outside, remove the cotter pin holding the long rod into the clutch pedal. screw the rod out of the clutch throwout bearing holder 2 turns and reinstall into the clutch pedal. try it and see if you need another turn or two.
john
03-15-2004 19:43:37
 Re: Re: Clutch adjustment in reply to steve, 03-15-2004 18:44:20
Thanks Steve I will try adjusting the rod. I have the tractor together.
