Front wheel bearings for a C
jal-SD
03-15-2004 07:36:24
We are looking for the part numbers for the front wheel bearings for my brother's C. We think the inside bearings may be too small, as they won't tighten up before the 4.00 X 15 tires come together at the bottom. The bearings are not bad, we just think they may be too small. They are the same on both sides, so we would like correct bearing cone & cup #'s for both inside & outside bearings. Can some one help?
Although we have several "chunks" of old iron, this is the only AC we have & we don't have a parts book or a good dealer left in the area. Also, where can we get manuals for this old girl? Thanks in advance for any help you might be able to give us. (My $0.02 worht. jal-SD)
CH
03-15-2004 14:45:57
 Re: Front wheel bearings for a C in reply to jal-SD, 03-15-2004 07:36:24
The inner bearing part # 209926, assembly #228459. Hope this helps.
jal-SD
03-16-2004 06:12:38
 Re: Re: Front wheel bearings for a C in reply to CH, 03-15-2004 14:45:57
Thanks, that will heip, I'm sure. Is that an AC part # or the actual bearing #? (Another $0.02 worth. jal-SD)
CH
03-18-2004 10:45:50
 Re: Re: Re: Front wheel bearings for a C in reply to jal-SD, 03-16-2004 06:12:38
Timken 15112, I think the 2 is right. Getting too small for my eyes.
