Spindle shaft bushings
CH
03-14-2004 16:05:22
Can anyone tell me the inside and outside diameters and length of the spindle shaft bushings on a B? Thanks guys.
steve
03-15-2004 18:36:38
 Re: Spindle shaft bushings in reply to CH, 03-14-2004 16:05:22
OOPS-- the spindel is 1-1/4 inch diameter. the bore of the axle is 1-3/8 diameter, so it is very thin. took one out, it is 1-1/4 inch long. you can get 1-3/4 in pretty easy (two per side) which would give more surface contact and support. i noticed 1/3 of the wear was in the pin and the other 2/3 was the brass bushing. chaning them helps, but still some play.
steve
03-15-2004 15:28:06
axle bushings are 1.250 inch bore, i think the OD was 1.750. i just bought a set 2 months ago from McMaster Carr and installed. Also the king pins were worn on another B i did, and i turned them down to 1-3/16 and bought standard bushings in that size to "repair".
CH
03-16-2004 14:55:37
 Re: Re: Spindle shaft bushings in reply to steve, 03-15-2004 15:28:06
Thanks Steve. I found the original bushings at AGCO. That was before I pulled the spindles and found the former owner didn't believe in grease. I'm probably going to turn the shafts and save the new bushings for the other B I'm doing next. Where did you find the oversize bushings? Other problem I've got is the conical hole at the top of one has oblongated. Gonna have to MIG some metal into it and machine it back out..
It never ends. Thanks, Charlie
