Shifter pivot erosion
Scott, MO
03-13-2004 14:01:33
The pivot on my shifter is all rusted away, it's on a 49 WD. The shifter falls completely thru the hole inside the tower, and you can pull it straight up and out of the housing. I'm going to attempt to weld it up and turn it back down, does anyone know what the outside diameter of the pivot should be? Has anyone seen this problem before, what did you do to fix it other than spend the $125. for a new shift lever.
Does anyone have a good used one that they could part with? any help would be appreciated.
oleblu
03-13-2004 15:06:11
 Re: Shifter pivot erosion in reply to Scott, MO, 03-13-2004 14:01:33
Scott, I have a shifter from a WD, not sure what year. It is a straight one. I'd be real willing to part with it. Not sure what it's worth. Drop me an e-mail. I'm in Galesburg, IL.
