Hi Sue, There are two different persian oranges used by AC. One that was used prior to about 1960 is sometimes referred to as persian #1. It is a pumpkin shade of orange. The later persian orange is sometimes referred to as persian #2. It has much more red in it and is the one you are likely to get from most tractor paint suppliers. Here's a visual of the two different shades as compared with an original part for a '42B:
The early pumpkin shade is available in a reasonably high quality automotive paint in two different basic chemistries (acrylic enamel and acrylic urethane) and two systems (single stage and basecoat/clearcoat). The mix number from PPG is 60080. It is available in PPG's OMNI line of cost effective autmotive paints as OMNI MAE 60080 for the acrylic enamel, OMNI MTK 60080 for the acrylic urethane and OMNI MBC 60080 for the basecoat/clearcoat. The MAE and MTK are both single stage paints that do not require a separate clearcoat. The MAE can be used with or without a hardener, although a hardener is generally recommended. The MTK requires a hardener. The clearcoat that is used with the MBC also requires a hardener. Hardeners pose some significant health-safety problems for those who do not have specialized breathing apparatus so I would recommend caution before deciding on using such products. The above paints will likely be at least twice as expensive ($50+ per gal) as the synthetic (alkyd) enamels you are likely to find in the tractor supply outlets and will have to be specifically mixed at a PPG paint supplier. PPG used to market an outstanding acrylic enamel called Delstar. It is a higher- end product than the OMNI line and would be more expensive still if you can get it in your area. It hasn't been available in NH for a number of years, having been dropped by the local jobbers (dealers) in favor of the cheaper OMNI MAE product. Delstar in the pumpkin shade of persian orange would be referred to as PPG DAR 60080. One note: all the above paints are formulated for spray application and not for brush work. While a brush can be used for small parts, the relatively fast dry characteristics could lead to difficulty with brush strokes showing when applied to large areas. If it's brush work you wish to do, I would stick to a slow-dry synthetic enamel (with poorer fade and chemical resistance) but I am not aware of a source of the early persian in that chemistry. Rod
