WD45 oil out the exhaust/intake manifold joint
Vic Lovejoy
03-09-2004 01:22:00
Well, I posted here a couple of days ago that I had rebuilt the carb and the thing actually ran... after letting it run I noticed it was getting a chuff and a puff of smoke every once in a while, then saw a 4-inch wide stream of oil down the side of the engine. The oil is coming from the manifold/cylinder head joint on the rear two connections, and really pouring out. I checked the spark plug on the two rear cylinders and they are both wet with oil.
I guess it's time to either junk it or start tearing it down. I wanted very badly to restore this one so I am probably at least going to start taking the head off to see what's going on inside.
If y'all have suggestions of what to look for (I have some ideas - valve guides, cracked head, cracked sleeve, cracked block) and the best ways to fix it I would appreciate it.
Is it possible to weld a cracked head and have it work ok? Just curious.
Any insight would be greatly appreciated.
vic
Dave K
03-14-2004 16:04:54
 Re: WD45 oil out the exhaust/intake manifold joint in reply to Vic Lovejoy, 03-09-2004 01:22:00
You might have a plugged oil return hole in the head, allowing oil to build up in there and seeking a way out such as around the valve guides and down into the manifold. Take off valve cover first, run engine, see whats going on in there. If can't determine remove head and check it out. The rocker arm shaft should have a cork in each end to prevent excess oil and if one or both are missing you should have low or no oil pressure and one heck of a lot of oil up there!
Dave
Dale
03-11-2004 06:26:53
Before you get too excited, remove the plugs, spin the engine over to evacute the cylinders, and then try NEW plugs and NOT Champions, you may have only severely fouled some plugs. Dale
Vic Lovejoy
03-11-2004 07:15:51
 Re: Re: WD45 oil out the exhaust/intake manifold j in reply to Dale, 03-11-2004 06:26:53
Dale, I'll try the plugs-out cranking to clear the cylinders, but would the fouled plug cause oil to enter the combustion chamber? I'm getting a large stream of oil out the exhaust manifold joint (it's covered the entire engine and frame with little spots of oil from spatter, and the stream down the side of the enigne is about 4 inches wide).
I'm kind of looking forward to taking it apart to see what the guts look like. I think it would be much less expensive to do a sleeve/piston/ring replacement, even with having to buy some tools, than it would be to go out an buy another tractor.
Anyways, I'll do the plugs out cranking just to see what comes out.
vic
Dale
03-11-2004 07:44:12
 Re: Re: Re: WD45 oil out the exhaust/intake manifo in reply to Vic Lovejoy, 03-11-2004 07:15:51
The reason you may be seeing an oily mixture is fouled plugs will cause the gas/air mixture to critically wash oil residue off the cylinder wall which may have been diluted with excessive gas getting into the crankcase. This can cause a very visual discharge from the exhaust. During a long winter like we're having here in the upper Midwest we see several tractors at the shop with these same symptoms, in fact 6 so far and all were alright when cleaned up. There may be rebuilds in the future here, but gas and ignition problems are most prevalent. Electronic ignition conversion will help a lot in this situation, call us for more info, Dale 920 295 3278
Vic Lovejoy
03-15-2004 13:12:57
 Re: Re: Re: Re: WD45 oil out the exhaust/intake ma in reply to Dale, 03-11-2004 07:44:12
Hey group, I followed Dale's suggestions and installed champion plugs, gapped correctly. The engine started within 1/2 a crank and ran very well this morning (when it was cold outside).
Had a nice light gray smoke and no oil out the exhaust. This afternoon when I went out to start it, the engine will run but runs very rough and as soon as the choke is pushed in even 1/4 inch the engine dies. I've tried adjusting the main jet (the whole thing started with a carb rebuild) and the full load screw, but haven't been able to get it to run. I set it at 1 1/2 turns and the main load screw at 1 1/4 turns, and it ran good this morning when it was about 40 degrees, but now it's about 57 and it won't run.
One thing I did today was put a 6" extension on the fuel line because it wasn't reaching the new filter head connection (with the new filter head screwed in the old fuel line didn't reach). I used a black rubber fuel line and clamps. I didn't think that would change the way it runs but I could be wrong. In either case I have cut the old steel line and put the black flexible line on in the middle to extend it.
I don't know what to do now. The battery keeps running down because I'm cranking it to death trying to get it to run long enough to figure out what's going on.
I have the battery on the charger so I guess I'll keep trying until I figure out why it won't run unless the choke is on 100% choke.
Any suggestions would be appreciated, and thank you Dale and others for your advice. The new plugs seem to have fixed the oil out the exhaust.
vic
Wayne in Ms.
03-09-2004 14:37:10
Had the same problem with my wd. broken rings on #2 piston
David_T (MO)
03-11-2004 14:15:12
 Re: Re: WD45 oil out the exhaust/intake manifold j in reply to Wayne in Ms., 03-09-2004 14:37:10
Had the same problem with my WD45 (#1 and #4 leaking down the side of the block). New plugs cured it... for a while at least. New plugs twice a year are a lot cheaper than a rebuild.
