Needed; A PTO for a WD45
Paul
03-07-2004 05:54:23
I could use a PTO if anybody has one they would part with or know of a good place to look for one..... Thanks, Paul
Sid
03-07-2004 06:42:28
 Re: Needed; A PTO for a WD45 in reply to Paul, 03-07-2004 05:54:23
Are you looking for the PTO gearbox or the shaft? If I am not mistaken the gear box was also used on the older dumptrucks to power the hydraulic pump.
Paul
03-07-2004 07:12:17
 Re: Re: Needed; A PTO for a WD45 in reply to Sid, 03-07-2004 06:42:28
Sid, Gearbox only..... Shaft is fine. Actually all I need is the gears and new bearings which I think I can get through the local parts house. The gearbox itself is ok.
Rick
03-07-2004 06:04:10
Paul, E-mail me in regards to the pto that you are needing. Thanks,Rick
Paul
03-07-2004 07:13:07
 Re: Re: Needed; A PTO for a WD45 in reply to Rick, 03-07-2004 06:04:10
Rick, Email sent..... Paul
