jdemaris
03-06-2004 06:53:56
Re: Too much Battery? in reply to wolfy, 03-05-2004 18:04:14
I have to slightly disagree with the content of other posts. It is possible, and I've seen it happen, that a starter motor works fine with the battery and cables it was originally intended to be used with, but can give trouble if over-batteried. That's because, e.g., a 12 volt starting sytems is designed, on the average, to crank at 9 volts, not 12 volts. And . . . that cranking voltage, when it's real cold out, might drop to 7 or 8 volts. Now, put in a battery and cables twice the size, and the machine might crank at 10 or 11 volts instead of 9. That makes a big difference. The starter drive will slam in a lot faster, and the starter will spin faster. Some starters handle it fine, some don't. Obviously, there are many 6 volt starters that are now being cranked with 12 volt batteries, and most work great. Keep in mind though, that many newer 12 volt starters are not built as heavy as the older 6 volt units. One case-in-point. My 1964 SS Chevelle with a 327 H.P. engine. One winter, like a damn fool, I drove it instead of taking it off the road. Salt did a number on it. I had a few mornings, at -30 degrees F., it barely turned over. So, I put in dual tractor batteries and double-00 cable. Cold cranking voltage went from 7 volts to 11 volts. Difference was night and day. It cranked so fast it would almost scare you. It also started breaking starter drives left and right. I finally installed a brand new heavier starter along with a Delco drive that was rated HD with extra rollers. That lasted one month and the ring gear was starting to get chewed up. Finally decided to back to the O.E.M. setup.
