NEEDED: A FEW PARTS FOR 1935 WC
PWB
03-04-2004 19:01:05
I NEED THREE PARTS FOR A 35 WC. FIRST I NEED A REAR BEARING RETAINER. THIS PART IS IN THE AREA OF THE TRANSMISSION WHICH SLIPS OVER THE MAIN SHAFT SLEEVE (FACING THE DRIVERS SEAT). IT BOLTS RIGHT ONTO THE TRANSMISSION HOUSING WITH FOUR BOLTS. A PART CALLED THE PACKING CAP SLIPS OVER THE REAR BEARING RETAINER AND IS FASTENED TO THE RETAINER WITH TWO CAPSCREWS. THE SECOND PART I NEED IS THE SEAL INSIDE OF THIS PACKING CAP CALLED THE SLEEVE PACKING. I'M NOT SURE WHAT MATERIAL THIS IS MADE OF BUT IT HAS A QUARTER ROUND SHAPE. MY LOCAL DEALER SAID THE PART IS NO LONGER MADE. I'M WONDERING IF ANYONE OUT THERE HAS A NEW SLEEVE PACKING FOR SALE. IF NOT, WHAT CAN I USE IN IT'S PLACE? THE THIRD PART IS A SEAT SPRING ASSEMBLY. I NEED THE EARLIER VERSION SPRING MADE FOR THE UNSTYLED WC'S. THIS IS MADE UP OF TWO SECTIONS OF SPRING STEEL FORMED TOGETHER IN THE SAME SHAPE. THE BOTTOM SECTION IS SHORTER THAN THE TOP. THE LATER VERSION HAS A FEW BANDS SECURING THE TWO SECTIONS TOGETHER--I NEED THE FIRST VERSION USED PRIOR TO TRACTOR SERIAL #32568. THANK YOU ALL FOR YOUR HELP. PAT
