Lubrication for final drive on WC
Kevin
05-01-1999 20:42:48
Maybe I'm really bad at this but how do you get the fluid in the final drive on a '44 WC?
Jay Abrams
05-02-1999 10:36:27
 Re: Lubrication for final drive on WC in reply to Kevin, 05-01-1999 20:42:48
Kevin,
The system is very similar to the WD. Remove the plug on the lower half of the final drive housing. You can then add the gear oil with a funnel and a long tube. The WC manual says that each final drive holds 1 pint. Good luck. Jay
Kevin
05-03-1999 18:44:10
 Re: Re: Lubrication for final drive on WC in reply to Jay Abrams, 05-02-1999 10:36:27
Is the plug on the inside or outside of the final drive? Thanks for the help.
Larry
05-04-1999 11:08:44
 Re: Re: Re: Lubrication for final drive on WC in reply to Kevin, 05-03-1999 18:44:10
The drain plug is on the under side. The fill and or check plug is on the lower, inner side.
