Model C wiring
Jason
02-26-2004 09:21:56
does anyone have a picture or wiring diagram for the c, i have a autolite generator with a cut out and no lights. any help would be great. thanks in advance jason becker
Steve in N.J.
02-27-2004 19:43:58
 Re: Model C wiring in reply to Jason, 02-26-2004 09:21:56
We have restored/rebuilt OEM switches in stock if you want to install a switch, & wire your machine correctly. Drop us a line if interested.....
Steve/B&B Custom Circuits
james brown
05-09-2006 18:43:13
 Re: Re: Model C wiring in reply to Steve in N.J., 02-27-2004 19:43:58
can any one help
I have a late 40's model c allis chalmers need to know how to wire the light switch when we bought it it was not wired if any one can help please email me at [email protected]
Dick L
02-26-2004 09:58:35
This is picture 42 below. You should find what you need in pictures 40,41, and 42.
jason
02-26-2004 15:21:13
 Re: Re: Model C wiring in reply to Dick L, 02-26-2004 09:58:35
where do the 2 wires on the cutout go to, i know one goes to ammeter maybe? does the other go to the generator?. what i need to know is how to wire the generator up properly with the cutout.
steve
02-26-2004 18:51:40
 Re: Re: Re: Model C wiring in reply to jason , 02-26-2004 15:21:13
there are two terminals on the generator "A" and "F". -----The "A" terminal goes to the cutout and the other end of the cutout goes to the ampmeter, amp goes to the battery.
--Now for the "F" terminal. IT is basically the "ground" terminal. THE F runs to the light switch resistor. with the switch pushed off, the F goes thru the resistor to ground and limits the charge to 2 amps, since you have a resistance to ground. With the light switch pulled out (on) you get the F wire grounded directly, not thru the resistor, and this gives you full charge or about 8 amps. I dont know the terminal number on the switch that "F" goes to, but it would be the ungrounded side of the resistor. For a test, you can ground the "F" wire at the generator and see that you get a good 8 amp charge.
jason
02-26-2004 22:22:17
 Re: Re: Re: Re: Model C wiring in reply to steve, 02-26-2004 18:51:40
in that case where would you run the f terminal wire to if your not using lights. would i have to buy a special light switch with a resistor for a field wire or hook it somewhere else.
steve
02-27-2004 15:31:11
 Re: Re: Re: Re: Re: Model C wiring in reply to jason, 02-26-2004 22:22:17
well, i think the light switch resistor is about 2 ohms. you could get a resistor and hard wire to get 2 amp charge all the time. --- you could ground the F terminal and get 8 amps all the time, (ok if you only run an hour a couple times a week, would not run 8 hour per day like this)--- or you could connect to a toggle switch and turn the ground off manually and only charge an hour a day when you want. ---last, you could get a 6 volt voltage regulator and wire it up so the regulator cut in and out and charge the battery as it required charging, but this is probably the most expensive.----- to be cheap, i would connect to a toggle and charge it once a week when running.
Bubba
02-28-2004 13:01:02
 Re: Re: Re: Re: Re: Re: Model C wiring in reply to steve, 02-27-2004 15:31:11
The Field coils in these generators will not stand to run a full charge for long. Either have someone fix the systen properly as it was originally or install a voltage regulator that is matched to the generator. The cheap fix of a toggle switch will end up costing more in the long run.
