Question for CH
Dave R (MN)
02-25-2004 19:50:36
CH how did your engine turn out? Last I heard you were having trouble with the bearings. Did you end up getting it line bored? Just wondering.
CH
02-26-2004 13:22:52
 Re: Question for CH in reply to Dave R (MN), 02-25-2004 19:50:36
third party image
Look, here it is with a crank in it.
CH
02-26-2004 13:24:27
 Re: Re: Question for CH in reply to CH, 02-26-2004 13:22:52
Sorry, the pictures over in Parts and Pieces on the left of this page.
CH
02-26-2004 03:59:57
Bad. I found a crack running across one of the cap bolts, under the journal right over to the oil gallery. Found another block, put the sleeves in last night. Before I did anything, I put a straight edge accross the mains and measured the difference. Didn't want to get that far and find a problem.
Thanks for asking Dave. By the way, you don't know where one can find a steering rod with the worm for a B? Mine's broke right where the rod attaches to the worm. If I can't get one cheap, I'm gonna weld a solid rod to the worm and thread the other end for the wheel.
Dave R (MN)
02-26-2004 16:41:38
 Re: Re: Question for CH in reply to CH, 02-26-2004 03:59:57
I,ve got one for a C but I'm not sure they are the same as a B or not. The worm gear is good, the threads for the acorn nut are a little battered up but I think they can be cleaned up. Where are you at? I have no idea what shipping would be but I can check it out this weekend if you think you can use it.
CH
02-26-2004 17:41:51
 Re: Re: Re: Question for CH in reply to Dave R (MN), 02-26-2004 16:41:38
I'm in Northern New York State. Unfortunatly, the C worm is opposite thread. I would make my B turn left when I steered right. Thanks anyway Dave.
Charlie
