Head Bolt Question
Rick in KY
02-24-2004 10:45:39
I've got the head off my WD. One of the head bolts is suspect with some pitting above the threads. Can I use a Grade 8 bolt as a replacement? Also can someone tell me how to torque the two nuts at the thermostat housing. I have seen this somewhere but can't find it now. Thanks
JMS/MN
02-24-2004 19:53:05
 Re: Head Bolt Question in reply to Rick in KY, 02-24-2004 10:45:39
If you mean the bolts on the water manifold, where you cannot get a torque wrench with socket on- I use a 3/4 inch combination wrench, and compare the 'pull' with an already torqued bolt. Never could figure out any other way that might work. Fifty years ago, when Dad was doing the overhauls- he didn't have a complete socket set, much less a torque wrench. The tractors survived.
ken
02-24-2004 17:27:15
I put all new head bolts in a D19 that were grade 8 the D 19 will not keep a head gasket in with the old head bolts not sure about a WD
