Two hydralics on WD-45
So.IL. Farmer
02-22-2004 10:29:30
My friend just purchased an 8 wheel V rake that takes two way hydralics to operate.He would to use his AC WD-45 to pull this rake.I know we will need an aux dual valve from TSC and also aux oil tank for more oil capacity.The mans uncle an old AC mechanic said that the tractors pump wont work.Can this be done?Has anybody ever put two hydralics on a 45 without changing the pump to engine mounted.Iknow putting an engine mounted pump would be the best.But he said he just cant aford the expense right now.I need some advice.
PS thanks for your help I really enjoy YT.
steve
02-22-2004 19:02:00
 Re: Two hydralics on WD-45 in reply to So.IL. Farmer, 02-22-2004 10:29:30
you engage your present valve/pump to run all the time and output thru one hose. this hose is the supply to your new two way valve. one hose in (supply), one hose return (sump back to tank) and two hoses to "lift" and "return". just need to make sure you buy the right kind of new valve with open center, and when you put supply to "lift" the return is routed back to the "sump". might need to adjust the valve on the WD for proper output. maybe you can bypass the present valve and run pump direct to new valve?
David_T (MO)
02-24-2004 12:36:40
 Re: Re: Two hydralics on WD-45 in reply to steve, 02-22-2004 19:02:00
The control valves on the WD45 hydraulics are inside the pump so no way to bypass them. Set the pump controls to full lift, add your two-way control valve and a return oil line (many add a tee fitting to the hydraulic reservoir drain so as not to block the fill). Keep in mind this WD45 uses a high pressure/low volume system while most modern implements are low pressure/high volume. This means the implement will react slower than it would on a modern tractor and you will have to be careful about over-pressureing the implement. The WD45 can easily output 4000 psi if the pump is functioning normally. Modern system only put out 2000 psi. Installing a pressure bypass in the two-way control set at 2000 psi is a good safety measure.
Good luck!
