Allis Chalmers G Question
Michael
02-22-2004 08:45:42
I am going to look at 2 AC G I never had an AC before. I did look at pic on this site. And have a few questions. Are these pron to the front end coming off the ground and then over. Do they have hyd,pto? What type of attachment can you put on these? And if i discover after buying these they are beyond repair. Is there a market for the part.
Thanks Michael
Ted Ransdell
01-02-2006 14:56:16
 Re: Allis Chalmers G Question in reply to Michael, 02-22-2004 08:45:42
I have a 1954 G Model that I am restoring. It has a bush hog on it which is controled up and down by a lifting devise bolted to the frame just ahead of the steering wheel. This is rusted and I can not free the threaded rod up which is inside a tube. I would like to replace that part, does anyone know where I might buy one? Also I would like to know the correct paint color for the wheels.
Thanks, Ted
Al Epp (Waldorf, Md)
02-23-2004 17:20:00
Where I live, almost every farmer grew tobacco up until a few years ago. The buyout has stopped almost everyone from growing it, except a few diehards and some of the Amish farmers. When we were kids, my brother and I sometimes helped our neighbor when we weren't busy on our own farm. One farmer we helped had almost all AC equipment. I remember a CA, G, plow, disc, cultivator, and a grain drill with no end wheels, it must have hooked up to the hydraulic lift. The G was used to cultivate and also to plant tobacco. The planter mounted between the front and back wheels. My brother and I planted alot of tobacco on that little tractor.
Farmered
02-23-2004 05:21:17
Michael, The front may come up with a heavy pull but if the pull is hitched to the regular drawbar there is no danger of it going over. Hydraulics were an option as was the PTO. The PTO is not conventional and is by way of a pulley on the left side ahead of the engine. It is for AC attachments or for other belt driven attachments such as pumps and could be fitted with a flat pulley or a V belt pully or a sprocket. Caution: The pulley is part of the seal and takes a special pulley. Don't worry about not having an AC before. The G is more different than other models of AC than most other makes of conventional tractors are. Ed
Ronnie in TX.
02-22-2004 20:53:20
Webpage
mike
02-29-2004 22:27:32
 Re: Re: Allis Chalmers G Question in reply to Ronnie in TX., 02-22-2004 20:53:20
i want to thank you for shareing those pix with us.. i`ve always admired the "G" .. makes me want all the more.. thanks again
Pig Dung
02-22-2004 15:03:12
Yes they are very light in front end a weight is availabile they are excelent cuilivator tractors ther is also a 1 bottom plow for it also a cycle bar mower there may be more i'm not sure ! there is a very good market fot parts
Michael
02-23-2004 07:37:05
 Re: Re: Allis Chalmers G Question in reply to Pig Dung, 02-22-2004 15:03:12
Thanks for the info guys, I guess if the price end up right and they have the grader blade attachment or mower I will have to get them.
thanks
Michael
