WD or WD-45
Merf
02-22-2004 06:25:18
I loked at a tractor with WD-45 decals. However the serial number is WD98211. Are there visual observation that determine if this is a WD or WD-45? Any help is appreciated. Thanks Merf
Phil Munson
02-22-2004 07:22:46
 Re: WD or WD-45 in reply to Merf, 02-22-2004 06:25:18
The block on a WD is U-3019, a 45 block is a six digit number, 226XXX.
John (C-IL)
02-22-2004 06:49:20
With that serial number it should have had a straight shifter. That tractor should have a plate over the lifter galley on the right side of the engine. If it is original it will have a magneto rather that a distributor. There are other things but those are the big ones.
rosmerf
02-22-2004 07:11:22
 Re: Re: WD or WD-45 in reply to John (C-IL), 02-22-2004 06:49:20
Thanks for your comments. This shift lever is not straight, it has a bend in it. This tractor has power steering and has a distributor. Can you tell me any more about the lifter gallery plate?? or any other visual differences? I will be out for a while but will look forward to any additional information. Thanks Merf
John (C-IL)
02-22-2004 07:28:59
 Re: Re: Re: WD or WD-45 in reply to rosmerf, 02-22-2004 07:11:22
The lifter galley plate is very obvious, it runs the entire length of the engine and is about 6 inches high. The curved shifter was introduced to the WD in 1952 at serial number 127008. The Delco-Remy distributor was introduced in 1953 at serial number 136318. The change from WD to WD45 was a running change and was finalized when the 226 ci engine was included in 1953. Factory power steering was introduced in 1956.
John (C-IL)
02-22-2004 06:52:27
BTW, that's a 1951 model. The WD45 was introduced in 1953 at serial number 146607.
