WD45 Uses around the small farm
Vic
02-22-2004 06:00:40
I'm using a WD45 around our 8 acres for bush-hogging and have used it to pull a tree that fell down.
Does anyone use their WD45 to move round hay bales? I'm also going to get a grader blade so I can clean our 250 foot driveway. I'm mostly wondering about the ability to carry hay bales with it.
Thanks in advance!
vic
David_T (MO)
02-24-2004 12:30:14
 Re: WD45 Uses around the small farm in reply to Vic, 02-22-2004 06:00:40
I use my WD45 for all of those jobs, even the tree. Handles the round bales very well but you don't want to use first gear or try to start moving with the nose pointed up a hill if you have a big one on the spike. She will rear on you. The only time I have to stear with the brakes is when there's snow on the ground. No big deal even then. Just keep it in your head you've got almost as much weight behind the rear axle as you do in front and you'll do fine. (I had a tougher time getting the hang of the hand clutch while brush-hogging.)
John (C-IL)
02-22-2004 06:55:42
THe WD45 will do it, but it is really a little too light to carry the big round bales.
Aaron SEIA
02-22-2004 10:12:00
 Re: Re: WD45 Uses around the small farm in reply to John (C-IL), 02-22-2004 06:55:42
Mine did do it for a while, then the pump quit. Not sure if the 2 are related or not. I just know that anything over about 1100 lbs will make you wish you had a bigger tractor. If you had a full stack of front end weights and fluid in your front tires you could maybe do it, but you'd still be steering with your brakes.
Aaron SEIA
