Please keep in mind that just because it shows as full on the dipstick does not mean the oil is getting pumped through the system. The pick-up tube could be clogged, the pump could be broken, the oil filter could be clogged, the fan belt could be broken or loose, etc. The pressure gauge is there to indicate that the system is pessurized and oil is being pumped throughout the engine. The oil gauge on my 'B' is not in good shape, water got inside the glass and therefore the face is rusted and unreadable and the glass is dirty on the inside, but it does 'read'. The indicator arm still responds and tells me the pump etc. is still working so I know the system is getting oiled. I know most vehicles today do not have oil pressure gauges and you can safely assume that all is ok as long as the oil level on the dipstick is good. But this is not true of older engines. There are sensors and such on newer engines that will let you know of problems with the oil system that older motors simply do not have. The only system that ensures older engines are running properly, is the user. I hghly recommend that you get the user's and shop manuals for the Mod. B and read them thouroughly before you continue. I only say this in case you have not aquired these yet. Again, I wish you the best.
