whats a WC worth
jacob
02-21-2004 17:42:03
I have a 1935 WC I plan to put a new manifold, radiator, rear tires, ring set, one sleave, and a gasket set, and possibly a good coat of paint what do you think I should ask for it when it is all said and done. thanks Jake
SUSAN
08-10-2004 04:04:47
 Re: whats a WC worth in reply to jacob, 02-21-2004 17:42:03
I HAVE A WD45 AND IT NEEDS A OIL PUMP I THINK IT WOULD BE LOCATED INSIDE THE OIL PAN WHERE ELSE COULD IT BE PLEASE REPLY
jed
02-25-2004 09:54:29
You might get $800 to $1000.
JMS/MN
02-21-2004 18:09:53
On my '37 WC, the manifold was 125, the ring set was 100, engine gasket set was 140, primer paint and two finish coats was 150. Don't put an old piston in a new sleeve. S&P is about 100 per hole, used are less, but make sure they match. Radiator might be a couple hundred, tires- new, 300 or more, used, less.
