allis chalmers b
jeremy
02-20-2004 14:53:26
I have an 38 ac b which has no hydrolics,I've noticed that some of these tractors have a lever for belly mounted implements.Is this stock or mod.And can anyone show a picture of how they work.
jeremy
02-21-2004 15:33:32
 Re: allis chalmers b in reply to jeremy, 02-20-2004 14:53:26
Thanks alot yall!!!!! ! That was alot of help!!!!! !!!
Rod (NH)
02-21-2004 12:15:47
Here's a view of the two manual levers for the belly mower:
third party image
And here's a view of the two manual levers for the pick-up plows:
third party image
JB in VA
02-21-2004 17:52:29
 Re: Re: allis chalmers b in reply to Rod (NH), 02-21-2004 12:15:47
Of fthe primary subject here but, how do you post a pic inside a posted msg?
Thanx.
Rod (NH)
02-21-2004 18:21:50
 Re: Re: Re: allis chalmers b in reply to JB in VA, 02-21-2004 17:52:29
Hi JB,
There are two ways, the easy and the harder. The easy way is to simply insert the image URL (internet address of the image) in the "Optional Image URL" block that is located beneath all post boxes.
The harder way involves using html coding within the post box. The advantage here is that you have more control over exactly where the image appears in your post and you can have multiple images in the same post. Check out the img src tag on the internet for proper usage of this tag. There should be lots of html help info available.
third party image Rod
Rod (NH)
02-21-2004 11:25:35
Hi Jeremy,
I am not sure but I think you are asking about manual lift mechanisms for the B implements that were used for tractors without hydraulics. If that is the case, there are several such levers that were stock and unique to each implement. For example, the manual lift two way pick-up plows used two levers. One for was lifting and the other was for fine tuning the depth adjustment. JB's picture shows this depth adjustment lever, I believe. It does not show the manual lift lever since his tractor appears to have a hydraulic lift for the plows, which is entirely different. The belly sickle mower also has two manual levers that are stock and unique to the mower that was used on tractors without hydraulics. One was for lifting the cutter bar and the other was for adjusting the angle of the knife guards.
JB in VA
02-21-2004 17:50:43
 Re: Re: allis chalmers b in reply to Rod (NH), 02-21-2004 11:25:35
Thanx Rod... I am new to the AC 'B' and was not sure about my answer and I do have a single side hydraulic ram... Thanx for the info.
JB in VA
02-21-2004 01:04:16
I have the lever on my '51 'B', I will post a pic in the Tractor Photos gallery (look for pics from "JB in VA"). I can't tell you where to get one, but I can show you how mine is set up.
And Steve's reply on the hydraulics is correct. I have a single ram on the right side, it is a simple and robust system.
steve
02-20-2004 15:06:51
if you have a PTO shaft on the back of your tractor, you have the right housing. there is a blet pulley shaft on the left side (pto out the rear) and on the right side of the housing there is a sheetmetal plate about 4 inches square with 4 bolts holding it on. you need to buy a hydraulic pump, about $100. that fits this hole. it sticks inside and runs off the cam lobes on the pto shaft. lever is attached to the pump/valve. if you dont have a pto shaft, you have the wrong housing and need the entire assembly. yes it was factory equipment. i can send you a picture of the back end of tractor if you dont have the correct housing--- just send e-mail.
