WD 3 point
timk
02-20-2004 07:47:15
We are having trouble controlling our position of our two point on the way up. It wants to go all the way up and breaks the bolts on the plate above the pto. We need to know if wd had same stroke cylinders as wd 45. What do you think fellas? Yours in tractors, Tim K.
Sid
02-20-2004 18:54:27
 Re: WD 3 point in reply to timk, 02-20-2004 07:47:15
I can not understand why the arms would come up far enough to break "the bolts on the plate above the pto". Are you refering the the platform you step up on? I wonder if your cylinders have been taken off and put back on wrong or if they are not the original cylinders.
Ron
02-20-2004 18:27:17
You have to set the lever in the "Hold" position when the 3-point gets at the height that you want it.. If it is a little out of the "Hold" detent, it will creep all the way--either up, or down.. It does take a little getting used to the "feel" of the hold position...!!
Ron
02-20-2004 08:08:06
if you have the Hydrolics SET for "Hold" position, you should have a good feel for the position that lets it hold..
In "Traction Booster" mode, it will not hold...will go all the way.. The Cylinders were the same..
timk
02-20-2004 13:14:36
 Re: Re: WD 3 point in reply to Ron, 02-20-2004 08:08:06
Ron, We need to know why when we operate our 2 point that our lever only needs to move about 1 inch to bring the arms from totally down to way up to far in fact..... It is very strange and very troublesome to try to figure it out.
Thanks , Tim K.
