compression on a wd-45
chad
02-16-2004 10:54:47
What is the compression suppose to be on a wd-45?
since I am doing all this I might as well check and see where I am at and how close to being good it is.
thanks
Chad
Brian G. NY
02-17-2004 08:22:23
 Re: compression on a wd-45 in reply to chad, 02-16-2004 10:54:47
Very few manufacturers specify a compression value. Most just say that the difference between the compression of the highest and the lowest cyls. should not exceed 10%. However, The WD-45 manual specifically states that the Compression Pressure (gas engine) should be 125# at 500 RPM.
JW
02-16-2004 14:50:20
The service manual says 90
old
02-16-2004 11:50:23
My book doesn't have that info, but I know if its above 100 psi its fair to good. If I remember right new it should have been around 150 or so but anything above 100 is good for and old engine
chad
02-16-2004 11:57:42
 Re: Re: compression on a wd-45 in reply to old, 02-16-2004 11:50:23
that is what I was thinking. Lets hope that it is and I just need a good tune up.
old
02-16-2004 12:17:03
 Re: Re: Re: compression on a wd-45 in reply to chad, 02-16-2004 11:57:42
I have tractors that have run on less then 75psi in the cylinders but they wheren't real strong. But I have had others that way that ran great, tune ups go a long ways in old tractors. Another thing use only copper core wire to the plugs it makes a very big differance
