finding top dead center
chad
02-16-2004 08:39:20
Ok I am sorry for all the questions. I am familiar with the red tractors and how to find top dead center markings on them.
I am about to set the valves on a wd-45.
Where is the TDC marker locator at? Can you read it off the front crank pulley like on a farmall?
please help I have orded a shop manual but it is not here yet. I need to get this running good to move some snow!
Thanks
old
02-16-2004 09:12:55
 Re: finding top dead center in reply to chad, 02-16-2004 08:39:20
Its on the flywheel you view if through inspection port on the lower side of the clutch housing look for a DC mark
Aaron SEIA
02-16-2004 18:32:34
 Re: Re: finding top dead center in reply to old, 02-16-2004 09:12:55
You need to get under the clutch housing and remove the inspection plate. Best way to do it it remove the #1 spark plug, put your finger over the hole, and turn it over slow till you feel air rushing past your finger. That'll get you on the compression stroke. Then get under the thing and look for the mark on the flywheel. On my WD, it's just a milled groove. Groove goes straight down. Then you have #1 up at the end of the compression stroke.
Aaron SEIA
