ALLIS G
DAN
04-27-1999 12:09:20
I HAVE HAD PROBLEMS WITH MY G SKIPPING. I PUT NEW PLUGS, NEW PLUG WIRES, NEW DISTRIBUTOR CAP, NEW ROTARY BUTTON, CONDENSOR, POINTS, A HEAD BECAUSE OLD ONE LEAKED SOME. THE MOTOR WAS REBUILT AROUND 4 YEARS AGO. I THINK THE PROBLEM IS IN THE CARB. I PUT A KIT IN IT LAST FALL. BUT SOME HOW IT IS STILL FLOODING, AND FOULING OUT THE PLUGS. I HAVE BEEN TOLD IT MAY BE THE HIGH SPEED JET. THE CARB ADJUSTS WITH THE IDLE SCREW BUT STILL IS FLOODING. ANY SUGGESTIONS WOULD BE APPRECIATED. THANKS, DANIEL
JWL
05-02-1999 14:11:51
 Re: ALLIS G in reply to DAN, 04-27-1999 12:09:20
It sounds like either the choke is not opening fully or the needle valve is allowing excess fuel to enter the fuel bowl. This could be due to worn needle and seat,loose seat,mal adjusted float level, or excessive fuel supply pressure.
