WD45 / D17 Diesel Heads
TractorNutt
02-14-2004 20:31:54
Anyone out there know if a head off of a 262 CI D-17 Diesel will fit on a 230CI WD45 Diesel (Buda Engine). I know Cranks (longer stroke on the D17), rods, etc. will fit. Also are the injectors and valves larger on the D-17 or D-19. Any input on this would be greatly appreciated.
HD19
02-17-2004 09:06:42
 Re: WD45 / D17 Diesel Heads in reply to TractorNutt, 02-14-2004 20:31:54
As I understand, early d17 diesel will fit 45, later d-17 does not. Heads between D-17 and D-19 are different also. Special injector tips required for D-19. I found that out the hard way. Those tips cost $50.00 apeice. I could get D-17 tips for half that price. Why are you asking? Head cracked or?? If you have cracks on head surface over enery cell hole, that is ok. But if you have cracks around the valve seats, NOT good.
TractorNutt
02-17-2004 21:53:00
 Re: Re: WD45 / D17 Diesel Heads in reply to HD19, 02-17-2004 09:06:42
HD19, Thanks for the info on the heads.The head on my 45 diesel is fine. I thought maybe the D17 had larger valves in it. Do you know if they are larger? I'm in Texas but know of a used D-17 head up in Iowa laying in a shop and I'm going to wait until spring to go up there... You wouldn't have casting #'s on those early D17 heads would you? Thanks again
HD19
02-17-2004 22:44:45
 Re: Re: Re: WD45 / D17 Diesel Heads in reply to TractorNutt, 02-17-2004 21:53:00
TractorNutt I will look at different heads, but I believe if you just put 45 head back on, you will be saving your self lots of time. If I remember correctly the valves are the same. I have D17 Diesel tractor and WD45 Diesel engine. I keep looking for complete 45 Diesel tractor. Just looked up Surplus Tractor cat. numbers for valves. WD45D and D17D are both the same. Int. V1463, ex. V1462. You could buy 3 1/2" oversize pistons for the 230 engine at one time... dont know if you could now. Hope this info helps. I have thought about dropping D19 turbo engine into D17 or late 45 frame. Good Luck
TractorNut
02-23-2004 18:25:41
 Re: Re: Re: Re: WD45 / D17 Diesel Heads in reply to HD19, 02-17-2004 22:44:45
Thanks for the information on the valves/heads. On my 45 Buda I am using a D19 crank, larger sleeves and pistons and it is now up to a 262, same as the D17. Need to figure out what the next step is, thought maybe it was in the head with bigger valves. I'd try a turbo from a D19 if it was legal. Thanks again
HD19
02-24-2004 01:07:31
 Re: Re: Re: Re: Re: WD45 / D17 Diesel Heads in reply to TractorNut, 02-23-2004 18:25:41
Tractornut, I seen a fellow that had a 45Diesel set up for pulling. He also had a WILD D21 also reworked for pulling. He lives in Durand WI. His name is Mark Heitman. Nice fellow. Give him a call. no. is 715 673 4829
