stuck piston rings onwd45 pistons
larry
02-14-2004 19:05:44
what is the trick removing stuck rings off a good piston without damage to the piston when rings are stuck all the way around
old
02-14-2004 19:47:38
 Re: stuck piston rings onwd45 pistons in reply to larry, 02-14-2004 19:05:44
Theres a number of tricks that I know of, one is as the other guys say, another is to soak the piston in oil, or turpentine or diesel fuel, etc. Another is to put it in hot water and boil the water. Another is useing hot oil or diesel fuel
steve
02-14-2004 19:22:20
i break the ring into pieces as it is removed. find the "end" and pick at it with a small screew driver. in should break off an inch or two at a time. after removal i take a flat file and clean out the bottom and sides of the grooves. wil probalby be several thousands of buildup on the grove. finally, wash piston and get new rings.
Jerry
02-16-2004 05:14:13
 Re: Re: stuck piston rings onwd45 pistons in reply to steve, 02-14-2004 19:22:20
I have had good luck useing the plastic handle of a screwdriver. Just tap on the rings moving around the piston. The rings will pop out usually on the second time around.
