Centering front rims on Centers ?
Dale in I'N'
02-14-2004 17:02:29
Does any body have a good trick to position the centers on new rins for a 39 B ? Right now I have postioned centers by eye, then mounted centers whith rims on front spindles. Took a block of wood and sat on top of the steering thingey and turned the whole lot. Kept tapping with hickery hammer handle until the gap between the edge of the rim and the block of wood was even. I understand the edge of the rim may not be perfectly flat. Any help is appreciated...
Kevin (FL)
02-16-2004 18:36:29
 Re: Centering front rims on Centers ? in reply to Dale in I'N', 02-14-2004 17:02:29
Dale,
It sounds like you're trying to align the front rims after working on tie rods or something?? I've never had to do that yet on a B, but I would say a rough measurement can be taken from inside-to-inside on the rims, 1st at the forward side, then at the rear side. The measurements should read the same, unless there's supposed to be a little "toe-in". You could also C-clamp a straight-edge (something like a 6-foot long 2x2 angle iron) on both rims on the outside, parallel to the ground and then measure the inside dimension at the front of the rim and then at the forward-most section of the angle irons. Once the rims are both adjusted straight, the angle irons will be parallel and the spacing between them will be constant along their length. I don't have any experience with actual settings for that tractor (although we have several waiting for restoration), I think that will get your rims pretty straight. Once you get the rims where you want 'em, then tighten up the tie-rods. I would still verify that they're not supposed to be toeing in a little. Hope I didn't totally confuse you with all the words.
