WC wide front end
Shawn
02-14-2004 15:38:35
I have a WC with a wide front end that looks to be the same as those on the WD & WD45 the tube type. Although I have been told that this front end is not the original by a guy who deals in C & B parts at all the tractor shows. He stated the ones on the WC's were a rolled I beam type, sort of like some of the early B's but of a heavier build. The one I have is a tube type and looks to be original. I thought I had read that some WC's had this tube type wide front end along with the WD & WD45's. Who is correct? Thanks for your knowledge in advance.
John (C-IL)
02-14-2004 15:43:00
 Re: WC wide front end in reply to Shawn, 02-14-2004 15:38:35
If you are talking about the wide front from a WD/WD45 the B/C parts man is right. THe WD/WD45 front will work nicely, but is not original.
Shawn
02-14-2004 16:47:24
 Re: Re: WC wide front end in reply to John (C-IL), 02-14-2004 15:43:00
John I read somewhere that the last two years the WC was made came with the optional tube frame adjustable wide front. Which was the same as the WD and WD45. But the years prior to this the front end was the I-beam type? Is this not correct? Thanks
John (C-IL)
02-14-2004 20:19:11
 Re: Re: Re: WC wide front end in reply to Shawn, 02-14-2004 16:47:24
I stand corrected! I had to look it up, but the WC was offered with the adjustable wide front 47-48. Still may not be original to the tractor but it was offered, sorry for the misinformation.
Shawn
02-15-2004 03:12:36
 Re: Re: Re: Re: WC wide front end in reply to John (C-IL), 02-14-2004 20:19:11
Thanks for all your help in confirming this for me. You are also most likely correct in this is not a 47 or 48. Thanks Shawn
HD19
02-17-2004 22:55:33
 Re: Re: Re: Re: Re: WC wide front end in reply to Shawn, 02-15-2004 03:12:36
Take a look at tractor serial number and see what year it is and then start guessing...
