help
dennis
02-13-2004 12:37:13
I WOULD LIKE TO KNOW WHAT I HAVE. THE SERIAL # IS B12711. I THOUGH IT WAS A C BUTT WITH THE B IN THE SERIAL# I DON'T KNOW. CAN ANYONE HELP ME????
steve
02-13-2004 16:17:36
 Re: help in reply to dennis, 02-13-2004 12:37:13
Dennis, a B and C are basically the same tractor. have the same radiator, hood, motor, transmission and pto/ bevel gear compartments. THEy varry that the C is a foot wider on the rear axle and is normally, but not always a narrow front end. The B is only about 5 ft wide outside the rear wheels and is always a wide front end. Most B have a wishbone front axle. Once you see it you cant mistake if for anything else. THere are other small differences, but that is the quick take. If you got more questions, just ask. You might have a hydraulic pump on the rear - probably have a pto shaft. and if it is 39, probalby has hand brake levers, not foot.
allis fever 5
02-13-2004 15:08:17
According to serial number you listed and the serial number registry at the left side of this board, you have a 1939 B.I'm assuming you are talking about an Allis Chalmers. HTH Bob D. (La)
