WD 45 Diesel need engine help
Steven John
02-13-2004 07:09:38
I have my grandpa WD45 diesel and it is in need of a new block. It has stress cracks between the cylinders, the head may also be bad. Are there parts out there for this tractor or is this a hard one to fix? What other equiptment used this engine? I do not know a lot of AC tractors but would like to get this tractor running again. Any info would be appriciated.
TractorNutt
02-14-2004 20:49:40
 Re: WD 45 Diesel need engine help in reply to Steven John, 02-13-2004 07:09:38
As you probably know, the engine in the 45 is a 230CI Buda. The remanants of the Buda Engine Co. is now in Shreveport, LA. I have two 45 Diesels and they sent me missmatched sleeves and pistons causing a lot of problems. I had the same cracks and had them welded up and then machined the block on the top surface and then new sleeves. Be sure they don't shave much off the block or the piston will bang the head. Guess how I know? Got VERY expensive. You can get some of the engine parts from Clevite. Always worked with 2 cyl. JD's and this Buda ate my lunch.
old
02-13-2004 08:46:51
Value bilt has most if not all the parts you would need just drop the E and add .com
