wd and wd-45 hyd pump are they the same?
chad
02-13-2004 05:43:16
We have a bad pump on our wd-45 and I came across a hyd pump for a wd are they the same pump? can it be used for parts? or bolt right in?
thanks Chad
L Hud
02-13-2004 06:46:14
 Re: wd and wd-45 hyd pump are they the same? in reply to chad, 02-13-2004 05:43:16
The pumps are the same. It should be a bolt on deal. The pump on the 17 has more teeth on the drive gear. If you use a 17 pump change drive gears. Hope this helps.
