how to move the rear wheels on a WD45?
iamdes
02-11-2004 04:53:00
What is the best way to get the wheels moving on a WD45 to spread the rear wheels out?
The bolts are really stuck...
Ron
02-12-2004 16:59:49
 Re: how to move the rear wheels on a WD45? in reply to iamdes, 02-11-2004 04:53:00
Use penetrating oil on the cam locks..
If you can get them turned counter-clockwise all the way, the wheels will move...
Brad W wi
02-11-2004 07:25:51
Had the same problem,sprayed 'er down with penetrating oil and removed the locks, loosened the bolts and just used 'er for pulling some logs . it took about 5 min of pulling to move it , and then i just moved it to where I wanted it, and tightened the bolts down and replaced the locking pins
