Removal of dust cover under rotor and dist cap??
iamdes
02-10-2004 20:29:28
there is a dustcover that covers up the points and the condendsor in the distributor. How the heck do I get that thing off without shattering it? I tried a screwdriver and cracked off a little piece. It still works but I would like to replace the cond and points. Is there a trick???
thanks....
Scott
02-11-2004 21:40:17
 Re: Removal of dust cover under rotor and dist cap in reply to iamdes, 02-10-2004 20:29:28
Yes, it does just come off. I have seen some bugs that have a little clip under them. The bug goes on over it. Make sure it is off if you have one. It will prevent the dust cover you have from coming off. I'd try a little penetrating oil to help get it loose. All else fails, brake it off, clean up, and order a new one. They're not too expensive.
Steve in N.J.
02-11-2004 05:01:39
Sometimes those covers just get plain stuck on the distributor housing. Assuming it's a Delco, it should just "pop" off. Sometimes working a small bladed screwdriver or probe around the outside circumference of the distributor will eventually lift the cover up equally without breaking it. We have the covers in stock if you wind up cracking or breaking the cover to get it off. Take yer' time, it'll come off. Drop us a line if you wind up with a two piece cover...
Steve/B&B Custom Circuits
bryan g in mo
02-11-2004 04:37:13
it must be stuck, that part is still available from any auto parts store,in case you break it.either work with it some more or break it off
