WD 201/226 interchange
Wayne
02-09-2004 10:57:38
Anyone have experience in exchanging a stationary AC 226 for a WD 201 motor. Got it all solved except the front crankshaft pulley. It is too long. Also, I had to changed out the water pump, but that was not much of a problem just drilling out the holes 1/32inch. The pump and pully arrangement from the I-226 is about two inches too long for radiator clearance. The pulley from the 201 is not drilled correctly to fit the I-226 engine. I suppose the front pulley is not balanced, not a damper of any type? Anyone know of a solution. If the front pulley is not special balance why could I not just put a compression pulley/shieve arrangement in the correct location? I am not interested in using the hand crank so the front pulley lugs for that are not needed.
pj
02-10-2004 06:25:13
 Re: WD 201/226 interchange in reply to Wayne, 02-09-2004 10:57:38
All you have to do is bore out the 201 pulley to fit the 226 crank.You can take the pulley to the pros, or you can drill it out with a hole saw,drill bit.That is what I did [drilled the 201 pulley] any questions just post to this thread.
Wayne
02-10-2004 07:29:11
 Re: Re: WD 201/226 interchange in reply to pj, 02-10-2004 06:25:13
The pully off the 201 fits on the 226 crankshaft fine, except I would prefer it to have a keyway cut. My problem is that it is not the correct length and the pully does not line up with the waterpump pulley when the retaining bolt is in place. Guess I could retap the old pulley but... You probably used a 226 motor from a tractor which is essentially the same but I am trying to get an industrial stationary engine to replace the 201.
Thanks for the suggestion though!
