Hydraulic fluid for 1949 B
ACmaninNC
02-08-2004 16:27:02
What weight or type of hydraulic fluid should I put in the tranny and hydraulic cylndars. Put regular hydraulic fluid in it and the cylndars froze up.
AC
steve
02-08-2004 16:54:44
 Re: Hydraulic fluid for 1949 B in reply to ACmaninNC, 02-08-2004 16:27:02
original oil was straight 20 wt. most people today use universal hydraulic-transmission fluid. this is 20wt you can get at Wal Mart or farm store. what do you mean cyliders "froze". if there is water inside, you need to flush. after changing oil you might have air in the pump and have to prime?? if so, remove the hydraulic hose and raise valve untill it starts to squirt out into a bucket. collapes cylinder, then connect hose.
